Ir para o conteúdo principal
Dell Inspiron 14R SE 7420 Hard Drive Replacement
O que você precisa
  1. Dell Inspiron 14R SE 7420 Hard Drive Replacement, Disconnecting the Hard Drive Cable: passo 1, imagem 1 %32
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin".
    • CAUTION: To avoid data loss, do not remove the hard drive while the computer is On or in Sleep state.
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
    • Pull the pull-tab to disconnect the hard-drive cable from the system-board connector.
  2. Dell Inspiron 14R SE 7420 Hard Drive Replacement, Remove the Screws: passo 2, imagem 1 %32
    • Remove the screws that secure the hard-drive assembly to the computer base.
  3. Dell Inspiron 14R SE 7420 Hard Drive Replacement, Removing the Cable: passo 3, imagem 1 %32
    • Make a note of the hard-drive cable routing and remove the cable from the routing guides.
  4. Dell Inspiron 14R SE 7420 Hard Drive Replacement, Lifting the Hard-Drive Assembly: passo 4, imagem 1 %32
    • Lift the hard-drive assembly along with its cable away from the computer base.
  5. Dell Inspiron 14R SE 7420 Hard Drive Replacement, Pull the Interposer: passo 5, imagem 1 %32
    • Pull the interposer to disconnect the hard-drive cable from the hard-drive.
  6. Dell Inspiron 14R SE 7420 Hard Drive Replacement, Remove the Screws: passo 6, imagem 1 %32
    • Remove the screws that secure the hard-drive bracket to the hard drive.
  7. Dell Inspiron 14R SE 7420 Hard Drive Replacement, Sliding the Hard Drive: passo 7, imagem 1 %32
    • Slide the hard-drive off the hard-drive bracket.
  8. Dell Inspiron 14R SE 7420 Hard Drive Replacement, Align the Screw Holes: passo 8, imagem 1 %32
    • Align the screw holes on the NEW hard-drive bracket with the screw holes on the hard drive.
  9. Dell Inspiron 14R SE 7420 Hard Drive Replacement, Replace the Screws: passo 9, imagem 1 %32
    • Replace the screws that secure the hard-drive bracket to the hard drive.
  10. Dell Inspiron 14R SE 7420 Hard Drive Replacement, Connecting the Interposer: passo 10, imagem 1 %32
    • Connect the hard-drive cable interposer to the hard drive.
  11. Dell Inspiron 14R SE 7420 Hard Drive Replacement, Place the Hard-Drive Assembly: passo 11, imagem 1 %32
    • Place the hard-drive assembly in the hard-drive bay on the computer base.
  12. Dell Inspiron 14R SE 7420 Hard Drive Replacement, Replace the Screws: passo 12, imagem 1 %32
    • Replace the screws that secure the hard-drive assembly to the computer base.
  13. Dell Inspiron 14R SE 7420 Hard Drive Replacement, Routing the Hard-Drive Cable: passo 13, imagem 1 %32
    • Route the hard-drive cable through the routing guides on the computer base.
  14. Dell Inspiron 14R SE 7420 Hard Drive Replacement, Connecting the Hard Drive Cable: passo 14, imagem 1 %32
    • Connect the hard-drive cable to the system-board connector.
Linha de Chegada
Terrence15
Membro desde: 12/18/17
79.121 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.985 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 220
