Pular para o conteúdo principal
Introdução
In this guide, we will be showing you how to remove and replace the Hard Drive Assembly.
Peças
Nenhum componente especificado.
  1. WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in "Before You Begin".
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in "Before You Begin".
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
    • Remove the screw that secures the hard-drive assembly to the system board.
  2. Slide the hard-drive assembly in the direction shown in the illustration to disconnect it from the connector on the system board.
    • Slide the hard-drive assembly in the direction shown in the illustration to disconnect it from the connector on the system board.
  3. Lift the hard-drive assembly off the system board.
    • Lift the hard-drive assembly off the system board.
  4. Remove the four screws that secure the hard-drive bracket to the hard drive.
    • Remove the four screws that secure the hard-drive bracket to the hard drive.
  5. Kit de Reparo de Bateria do MacBook
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  6. Lift the hard drive away from the hard-drive bracket.
    • Lift the hard drive away from the hard-drive bracket.
  7. Place the NEW hard drive in the hard-drive bracket.
    • Place the NEW hard drive in the hard-drive bracket.
  8. Replace the four screws that secure the hard-drive bracket to the hard drive.
    • Replace the four screws that secure the hard-drive bracket to the hard drive.
  9. Place the hard-drive assembly on the system board.
    • Place the hard-drive assembly on the system board.
  10. Slide the hard-drive assembly to connect it to the connector on the system board.
    • Slide the hard-drive assembly to connect it to the connector on the system board.
  11. Replace the screw that secures the hard-drive assembly to the system board.
    • Replace the screw that secures the hard-drive assembly to the system board.
    • CAUTION: Before turning on the computer, replace all screws and ensure that no stray screws remain inside the computer. Failure to do so may result in damage to the computer.
Linha de Chegada
Uma outra pessoa concluiu este guia.
Terrence15
Membro desde: 18-12-2017
70.815 reputação
442 Guias de autoria
Equipe
Informative Technologies Inc. Membro de Informative Technologies Inc.
Community
15 Membros
925 Guias de autoria
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Todo: 40
