Introdução
In this guide, we will show you how to remove and replace the Hard Drive.
Peças
Não são necessárias peças.
  1. WARNING:  Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin".
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin".
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
    • Pull the pull-tab to disconnect the hard-drive cable from the system-board connector.
  2. Remove the screws that secure the hard-drive assembly to the computer base.
    • Remove the screws that secure the hard-drive assembly to the computer base.
  3. Make a note of the hard-drive cable routing and remove the cable from the routing guides.
    • Make a note of the hard-drive cable routing and remove the cable from the routing guides.
  4. Lift the hard-drive assembly along with its cable away from the computer base.
    • Lift the hard-drive assembly along with its cable away from the computer base.
  5. Pull the interposer to disconnect the hard-drive cable from the hard-drive.
    • Pull the interposer to disconnect the hard-drive cable from the hard-drive.
  6. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  7. Remove the screws that secure the hard-drive bracket to the hard drive.
    • Remove the screws that secure the hard-drive bracket to the hard drive.
  8. Slide the hard-drive off the hard-drive bracket. Slide the hard-drive off the hard-drive bracket.
    • Slide the hard-drive off the hard-drive bracket.
  9. Align the screw holes on the hard-drive bracket with the screw holes on the hard drive.
    • Align the screw holes on the hard-drive bracket with the screw holes on the hard drive.
  10. Replace the screws that secure the hard-drive bracket to the NEW hard drive.
    • Replace the screws that secure the hard-drive bracket to the NEW hard drive.
  11. Connect the hard-drive cable interposer to the hard drive.
    • Connect the hard-drive cable interposer to the hard drive.
  12. Place the hard-drive assembly in the hard-drive bay on the computer base.
    • Place the hard-drive assembly in the hard-drive bay on the computer base.
  13. Replace the screws that secure the hard-drive assembly to the computer base.
    • Replace the screws that secure the hard-drive assembly to the computer base.
  14. Route the hard-drive cable through the routing guides on the computer base.
    • Route the hard-drive cable through the routing guides on the computer base.
  15. Connect the hard-drive cable to the system-board connector.
    • Connect the hard-drive cable to the system-board connector.
Linha de Chegada
Terrence15
70.274 reputação
442 Guides authored
Equipe
Informative Technologies Inc. Membro de Informative Technologies Inc.
Community
15 Membros
925 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 15
Todo: 115
