Introdução
In this guide, we will be showing you how to remove and replace the Display Assembly.
O que você precisa
Remove the screws that secure the display assembly to the computer base.
Disconnect the antenna cables from the connectors on the Mini-Card.
Place the NEW display assembly in position and replace the screws that secure the display assembly to the computer base.
Connect the antenna cables to the connectors on the Mini-Card.
Replace the screws that secure the display assembly to the computer base.
