Ir para o conteúdo principal
Dell Inspiron 14R 5420 Display Assembly Replacement
O que você precisa
  1. Dell Inspiron 14R 5420 Display Assembly Replacement, Close the Display: passo 1, imagem 1 %32
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin".
    • Close the display and turn the computer over.
  2. Dell Inspiron 14R 5420 Display Assembly Replacement, Remove the Screws: passo 2, imagem 1 %32
    • Remove the screws that secure the display assembly to the computer base.
  3. Dell Inspiron 14R 5420 Display Assembly Replacement, Open the Display: passo 3, imagem 1 %32
    • Turn the computer over and open the display as far as possible.
  4. Dell Inspiron 14R 5420 Display Assembly Replacement, Disconnecting the Antenna Cables: passo 4, imagem 1 %32
    • Disconnect the antenna cables from the connectors on the Mini-Card.
  5. Dell Inspiron 14R 5420 Display Assembly Replacement, Remove the Screws: passo 5, imagem 1 %32
  6. Dell Inspiron 14R 5420 Display Assembly Replacement, Removing the Display Assembly: passo 6, imagem 1 %32
    • Lift the display assembly off the computer base.
  7. Dell Inspiron 14R 5420 Display Assembly Replacement, Placing the Display Assembly: passo 7, imagem 1 %32
    • Place the NEW display assembly in position and replace the screws that secure the display assembly to the computer base.
  8. Dell Inspiron 14R 5420 Display Assembly Replacement, Connecting the Antenna Cables: passo 8, imagem 1 %32
    • Connect the antenna cables to the connectors on the Mini-Card.
  9. Dell Inspiron 14R 5420 Display Assembly Replacement, Close the Display: passo 9, imagem 1 %32
  10. Dell Inspiron 14R 5420 Display Assembly Replacement, Replace the Screws: passo 10, imagem 1 %32
    • Replace the screws that secure the display assembly to the computer base.
Linha de Chegada
Terrence15
Membro desde: 12/18/17
79.091 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.985 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 1,103
