Ir para o conteúdo principal
Dell Inspiron 1464 Hard Drive Replacement
O que você precisa
  1. Dell Inspiron 1464 Hard Drive Replacement, Remove the Screws: passo 1, imagem 1 %32
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
    • Remove the two screws that secure the hard drive assembly to the computer base.
  2. Dell Inspiron 1464 Hard Drive Replacement, Sliding the Hard Drive Assembly: passo 2, imagem 1 %32
    • Slide the hard drive assembly to the right to disconnect it from the connector on the system board, then lift the hard drive assembly out of the computer base.
  3. Dell Inspiron 1464 Hard Drive Replacement, Remove the Screws: passo 3, imagem 1 %32
    • Remove the four screws that secure the hard drive to the hard drive bracket.
  4. Dell Inspiron 1464 Hard Drive Replacement, Lifting the Hard Drive: passo 4, imagem 1 %32
    • Lift the hard drive out of the hard drive bracket.
  5. Dell Inspiron 1464 Hard Drive Replacement, Replace the Screws: passo 5, imagem 1 %32
    • Replace the four screws that secure the hard drive bracket to the hard drive.
  6. Dell Inspiron 1464 Hard Drive Replacement, Placing the Assembly: passo 6, imagem 1 %32
    • Place the hard drive assembly in the computer base and push to connect the hard drive assembly to the connector on the system board.
  7. Dell Inspiron 1464 Hard Drive Replacement, Replace the Screws: passo 7, imagem 1 %32
    • Replace the two screws that secure the hard drive assembly to the computer base.
Linha de Chegada
Terrence15
Membro desde: 12/18/17
78.818 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.984 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 11
Duração total: 1,457
