Introdução
In this guide, we will be showing you how to remove and replace the Hard Drive.
Peças
Não são necessárias peças.
  1. WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
    • Remove the two screws that secure the hard drive assembly to the computer base.
  2. Slide the hard drive assembly to the right to disconnect it from the connector on the system board, then lift the hard drive assembly out of the computer base.
    • Slide the hard drive assembly to the right to disconnect it from the connector on the system board, then lift the hard drive assembly out of the computer base.
  3. Remove the four screws that secure the hard drive to the hard drive bracket.
    • Remove the four screws that secure the hard drive to the hard drive bracket.
  4. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  5. Lift the hard drive out of the hard drive bracket.
    • Lift the hard drive out of the hard drive bracket.
  6. Replace the four screws that secure the hard drive bracket to the hard drive.
    • Replace the four screws that secure the hard drive bracket to the hard drive.
  7. Place the hard drive assembly in the computer base and push to connect the hard drive assembly to the connector on the system board.
    • Place the hard drive assembly in the computer base and push to connect the hard drive assembly to the connector on the system board.
  8. Replace the two screws that secure the hard drive assembly to the computer base.
    • Replace the two screws that secure the hard drive assembly to the computer base.
Linha de Chegada
Terrence15
70.274 reputação
442 Guides authored
Equipe
Informative Technologies Inc. Membro de Informative Technologies Inc.
Community
15 Membros
925 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 27
Todo: 220
