Ir para o conteúdo principal
Dell Inspiron 1464 Display Assembly Replacement
O que você precisa
  1. Dell Inspiron 1464 Display Assembly Replacement, Note the Routing: passo 1, imagem 1 %32
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface.
    • Note the routing of the Mini-Card antenna cables and remove them from the routing guides on the bottom of the computer.
  2. Dell Inspiron 1464 Display Assembly Replacement, Remove the Screws: passo 2, imagem 1 %32
    • Remove the two screws on the bottom of the computer that secure the display assembly to the computer base.
  3. Dell Inspiron 1464 Display Assembly Replacement, Pull the Cables Up: passo 3, imagem 1 %32
    • Pull the Mini-Card antenna cables up through the slot in the computer base.
  4. Dell Inspiron 1464 Display Assembly Replacement, Note the Routing: passo 4, imagem 1 %32
    • Note the routing of the Mini-Card antenna cables and remove them from the routing guides on the palm rest.
  5. Dell Inspiron 1464 Display Assembly Replacement, Disconnect the Display Cable: passo 5, imagem 1 %32
    • Disconnect the display cable from the connector on the system board and remove the display cable grounding screw.
  6. Dell Inspiron 1464 Display Assembly Replacement, Remove the Screws: passo 6, imagem 1 %32
    • Remove the three screws that secure the display assembly to the computer base.
  7. Dell Inspiron 1464 Display Assembly Replacement, Removing the Display Assembly: passo 7, imagem 1 %32
    • Lift the display assembly off the alignment posts on the computer base.
  8. Dell Inspiron 1464 Display Assembly Replacement, Placing the Display Assembly: passo 8, imagem 1 %32
    • Use the alignment posts to place the NEW display assembly on the computer base.
  9. Dell Inspiron 1464 Display Assembly Replacement, Replace the Screws: passo 9, imagem 1 %32
    • Replace the three screws that secure the display assembly to the computer base.
  10. Dell Inspiron 1464 Display Assembly Replacement, Connecting the Display Cable: passo 10, imagem 1 %32
    • Connect the display cable to the connector on the system board and replace the display cable grounding screw.
  11. Dell Inspiron 1464 Display Assembly Replacement, Routing the Cables: passo 11, imagem 1 %32
    • Route the Mini-Card antenna cables through the routing guides on the palm rest.
  12. Dell Inspiron 1464 Display Assembly Replacement, Thread the Cables: passo 12, imagem 1 %32
    • Thread the Mini-Card antenna cables through the slot in the computer base.
  13. Dell Inspiron 1464 Display Assembly Replacement, Replace the Screws: passo 13, imagem 1 %32
    • Turn the computer over and replace the two screws that secure the display assembly to the computer base.
Linha de Chegada
Terrence15
Membro desde: 12/18/17
79.121 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.985 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 284
