Ir para o conteúdo principal
Dell Inspiron 1440 Hard Drive Replacement
O que você precisa
  1. Dell Inspiron 1440 Hard Drive Replacement, Remove the Screws: passo 1, imagem 1 %32
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
    • Remove the two screws that secure the hard drive assembly to the computer base.
  2. Dell Inspiron 1440 Hard Drive Replacement, Sliding the Hard Drive Assembly: passo 2, imagem 1 %32
    • Slide the hard drive assembly out of the hard drive compartment.
  3. Dell Inspiron 1440 Hard Drive Replacement, Remove the Screws: passo 3, imagem 1 %32
    • Remove the two screws that secure the hard drive bezel to the hard drive.
  4. Dell Inspiron 1440 Hard Drive Replacement, Remove the Hard Drive: passo 4, imagem 1 %32
    • Remove the hard drive.
  5. Dell Inspiron 1440 Hard Drive Replacement, Align the Screw Holes: passo 5, imagem 1 %32
    • Align the screw holes on the hard drive bezel with the holes on the hard drive.
  6. Dell Inspiron 1440 Hard Drive Replacement, Replace the Screws: passo 6, imagem 1 %32
    • Replace the two screws that secure the hard drive bezel to the hard drive.
  7. Dell Inspiron 1440 Hard Drive Replacement, Sliding the Hard Drive Assembly: passo 7, imagem 1 %32
    • Slide the hard drive assembly into the hard drive compartment until it is fully seated.
  8. Dell Inspiron 1440 Hard Drive Replacement, Replace the Screws: passo 8, imagem 1 %32
    • Replace the two screws that secure the hard drive assembly to the computer base.
Linha de Chegada
Uma outra pessoa concluiu este guia.
Terrence15
Membro desde: 12/18/17
79.131 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.986 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 22
Duração total: 1,795
