Ir para o conteúdo principal
Dell Inspiron 1440 Display Assembly Replacement
O que você precisa
  1. Dell Inspiron 1440 Display Assembly Replacement, Remove the Screws: passo 1, imagem 1 %32 Dell Inspiron 1440 Display Assembly Replacement, Remove the Screws: passo 1, imagem 2 %32
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface.
    • Remove the two screws from the computer base.
  2. Dell Inspiron 1440 Display Assembly Replacement, Disconnecting the Camera Cable: passo 2, imagem 1 %32
    • Disconnect the camera cable from the system board connector.
  3. Dell Inspiron 1440 Display Assembly Replacement, Removing the Cables: passo 3, imagem 1 %32
    • Make note of the Mini-Card antenna cables, camera cable, and the display cable routing and remove the cables from their routing guides.
  4. Dell Inspiron 1440 Display Assembly Replacement, Remove the Screws: passo 4, imagem 1 %32
    • Remove the two screws that secure the display assembly to the computer base.
  5. Dell Inspiron 1440 Display Assembly Replacement, Removing the Display Assembly: passo 5, imagem 1 %32
    • Lift and remove the display assembly from the computer base.
  6. Dell Inspiron 1440 Display Assembly Replacement, Placing the Display Assembly: passo 6, imagem 1 %32
    • Place the NEW display assembly in position and replace the two screws that secure the display assembly to the computer base.
  7. Dell Inspiron 1440 Display Assembly Replacement, Routing the Cables: passo 7, imagem 1 %32
    • Route the Mini-Card antenna cables, camera cable, and display cable through the routing guides.
  8. Dell Inspiron 1440 Display Assembly Replacement, Connecting the Camera Cable: passo 8, imagem 1 %32
    • Connect the camera cable to the system board connector.
  9. Dell Inspiron 1440 Display Assembly Replacement, Replace the Screws: passo 9, imagem 1 %32 Dell Inspiron 1440 Display Assembly Replacement, Replace the Screws: passo 9, imagem 2 %32
    • Replace the two screws at the bottom of the computer.
Linha de Chegada
Terrence15
Membro desde: 12/18/17
79.243 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.989 guias
Um comentário
Se puede upgradear la pantalla de esta laptop por una mejor ya sea un panel FHD IPS o no? Existe alguna compatibilidad para poder hacer un upgrade de pantalla? muchas gracias
djshebanana - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 492
