Introdução
In this guide, we will show you how to remove and replace the Display Assembly.
O que você precisa
Disconnect the camera cable from the system board connector.
Make note of the Mini-Card antenna cables, camera cable, and the display cable routing and remove the cables from their routing guides.
Remove the two screws that secure the display assembly to the computer base.
Lift and remove the display assembly from the computer base.
Place the NEW display assembly in position and replace the two screws that secure the display assembly to the computer base.
Route the Mini-Card antenna cables, camera cable, and display cable through the routing guides.
Um comentário
Se puede upgradear la pantalla de esta laptop por una mejor ya sea un panel FHD IPS o no? Existe alguna compatibilidad para poder hacer un upgrade de pantalla? muchas gracias
