Ir para o conteúdo principal
Dell Inspiron 1428 Hard Drive Replacement
O que você precisa
  1. Dell Inspiron 1428 Hard Drive Replacement, Remove the Screws: passo 1, imagem 1 %32
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in "Before You Begin".
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
    • Remove the two screws that secure the hard-drive cover to the computer base.
  2. Dell Inspiron 1428 Hard Drive Replacement, Pry out te Hard-Drive Cover: passo 2, imagem 1 %32
    • Pry out the hard-drive cover using your finger.
  3. Dell Inspiron 1428 Hard Drive Replacement, Remove the Screws: passo 3, imagem 1 %32
    • Remove the two screws that secure the hard-drive assembly to the computer base.
  4. Dell Inspiron 1428 Hard Drive Replacement, Disconnecting the Hard Drive Assembly: passo 4, imagem 1 %32
    • Pull the pull-tab on the hard-drive assembly towards the right to disconnect the hard-drive assembly from the system board connector.
  5. Dell Inspiron 1428 Hard Drive Replacement, Lifting the Hard-Drive Assembly: passo 5, imagem 1 %32
    • Lift the hard-drive assembly out of the computer base.
  6. Dell Inspiron 1428 Hard Drive Replacement, Remove the Screws: passo 6, imagem 1 %32
    • Remove the four screws that secure the hard drive to the hard-drive cage.
  7. Dell Inspiron 1428 Hard Drive Replacement, Placing the Hard Drive: passo 7, imagem 1 %32
    • Place the NEW hard drive in the hard-drive cage.
  8. Dell Inspiron 1428 Hard Drive Replacement, Replace the Screws: passo 8, imagem 1 %32
    • Replace the four screws that secure the hard drive to the hard-drive cage.
  9. Dell Inspiron 1428 Hard Drive Replacement, Placing the Hard-Drive Assembly: passo 9, imagem 1 %32
    • Place the NEW hard-drive assembly in the computer base.
  10. Dell Inspiron 1428 Hard Drive Replacement, Connecting the Hard-Drive Assembly: passo 10, imagem 1 %32
    • Slide and connect the hard-drive assembly to the system board connector.
  11. Dell Inspiron 1428 Hard Drive Replacement, Replace the Screws: passo 11, imagem 1 %32
    • Replace the two screws that secure the hard-drive assembly to the computer base.
  12. Dell Inspiron 1428 Hard Drive Replacement, Align the Tabs: passo 12, imagem 1 %32
    • Align the tabs on the hard-drive cover with the slots on the computer base and snap the hard-drive cover into place.
  13. Dell Inspiron 1428 Hard Drive Replacement, Replace the Screws: passo 13, imagem 1 %32
    • Replace the two screws that secure the hard-drive cover to the computer base.
Linha de Chegada
Terrence15
Membro desde: 12/18/17
79.243 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.989 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 77
