Ir para o conteúdo principal
Dell Inspiron 1425 Display Assembly Replacement
O que você precisa
  1. Dell Inspiron 1425 Display Assembly Replacement, Remove the Screws: passo 1, imagem 1 %32
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in "Before You Begin".
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Remove the two screws from the computer base.
  2. Dell Inspiron 1425 Display Assembly Replacement, Loosen the Cable: passo 2, imagem 1 %32
    • Loosen the display cable grounding screw.
  3. Dell Inspiron 1425 Display Assembly Replacement, Disconnecting the Display Cable: passo 3, imagem 1 %32
    • Disconnect the display cable from the connector on the system board.
  4. Dell Inspiron 1425 Display Assembly Replacement, Remove the Screws: passo 4, imagem 1 %32
    • Remove the four screws that secure the display assembly to the computer base.
  5. Dell Inspiron 1425 Display Assembly Replacement, Removing the Display Assembly: passo 5, imagem 1 %32
    • Lift the display assembly off the computer base.
  6. Dell Inspiron 1425 Display Assembly Replacement, Placing the Display Assembly: passo 6, imagem 1 %32
    • Place the NEW display assembly in position and replace the four screws that secure the display assembly to the computer base.
  7. Dell Inspiron 1425 Display Assembly Replacement, Routing the Cables: passo 7, imagem 1 %32
    • Route the display cable and Mini-Card antenna cables through the routing guides.
  8. Dell Inspiron 1425 Display Assembly Replacement, Connecting the Display Cable: passo 8, imagem 1 %32
    • Connect the display cable to the connector on the system board.
  9. Dell Inspiron 1425 Display Assembly Replacement, Tighten the Cable Screw: passo 9, imagem 1 %32
    • Tighten the display cable grounding screw.
  10. Dell Inspiron 1425 Display Assembly Replacement, Replace the Screws: passo 10, imagem 1 %32
    • Replace the two screws at the bottom of the computer.
Linha de Chegada
Terrence15
Membro desde: 12/18/17
79.131 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.986 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 5
Duração total: 161
