Ir para o conteúdo principal
Dell Inspiron 1420 Hard Drive Replacement
O que você precisa
  1. Dell Inspiron 1420 Hard Drive Replacement, Loosen the Screws: passo 1, imagem 1 %32
    • CAUTION: Before working inside your computer, Follow the procedures in Before You Begin.
    • Turn the computer over.
    • Loosen the two captive screws securing the hard drive cover and then remove the cover.
  2. Dell Inspiron 1420 Hard Drive Replacement, Remove the Hard Drive Assembly: passo 2, imagem 1 %32 Dell Inspiron 1420 Hard Drive Replacement, Remove the Hard Drive Assembly: passo 2, imagem 2 %32
    • Remove the hard drive assembly using the pull-tab.
  3. Dell Inspiron 1420 Hard Drive Replacement, Removing the Screws: passo 3, imagem 1 %32
    • Remove the two screws securing the hard drive to the hard drive assembly.
  4. Dell Inspiron 1420 Hard Drive Replacement, Removing the Hard Drive: passo 4, imagem 1 %32 Dell Inspiron 1420 Hard Drive Replacement, Removing the Hard Drive: passo 4, imagem 2 %32
    • Slide out the hard drive from the hard drive assembly.
  5. Dell Inspiron 1420 Hard Drive Replacement, Sliding the Hard Drive: passo 5, imagem 1 %32 Dell Inspiron 1420 Hard Drive Replacement, Sliding the Hard Drive: passo 5, imagem 2 %32
    • Slide the NEW hard drive in the hard drive assembly.
    • NOTICE: Use firm and even pressure to slide the drive into place. If you use excessive force, you may damage the connector.
  6. Dell Inspiron 1420 Hard Drive Replacement, Tighten the Screws: passo 6, imagem 1 %32
    • Tighten the two screws to secure the hard drive to the hard drive assembly.
  7. Dell Inspiron 1420 Hard Drive Replacement, Placing the Hard Drive Assembly: passo 7, imagem 1 %32
    • Place the hard drive assembly in the hard drive bay by aligning the tabs on the hard drive assembly with the slots in the bay and pressing the connector end down.
  8. Dell Inspiron 1420 Hard Drive Replacement, Replace the Hard Drive Door: passo 8, imagem 1 %32 Dell Inspiron 1420 Hard Drive Replacement, Replace the Hard Drive Door: passo 8, imagem 2 %32
    • Replace the hard drive door and tighten the screws.
Linha de Chegada
Terrence15
Membro desde: 12/18/17
79.121 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.985 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 12
Duração total: 1,061
