Introdução
In this guide, we will show you how to remove and replace the Hard Drive.
Peças
Não são necessárias peças.
  1. CAUTION: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in  Before You Begin.
    • CAUTION: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
    • CAUTION: If you remove the hard drive from the computer when the drive is hot, do not touch the metal housing of the hard drive.
    • Remove the two screws securing the hard drive assembly to the system board.
  2. Holding the connector end of the hard drive assembly, pull the hard drive assembly from the system board connector.
    • Holding the connector end of the hard drive assembly, pull the hard drive assembly from the system board connector.
  3. Free shipping on all orders over US$100 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  4. Press down on the hard drive at the non-connector end slot to remove the hard drive off the hard drive cage.
    • Press down on the hard drive at the non-connector end slot to remove the hard drive off the hard drive cage.
  5. Place the NEW hard drive in the hard drive cage and press it down until it snaps into place.
    • Place the NEW hard drive in the hard drive cage and press it down until it snaps into place.
  6. Push down the hard drive assembly in place by aligning the hard drive connector with the system board connector.
    • Push down the hard drive assembly in place by aligning the hard drive connector with the system board connector.
  7. Replace the two screws securing the hard drive assembly to the system board.
    • Replace the two screws securing the hard drive assembly to the system board.
Linha de Chegada
Terrence15
70.653 reputação
442 Guides authored
Equipe
Informative Technologies Inc. Membro de Informative Technologies Inc.
Community
15 Membros
925 Guides authored
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 8
Todo: 46
