Ir para o conteúdo principal
Dell Inspiron 14-7437 Thermal Cooling Fan Replacement
O que você precisa
  1. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement, Base Cover: passo 1, imagem 1 %32 Dell Inspiron 14-7437 Thermal Cooling Fan Replacement, Base Cover: passo 1, imagem 2 %32
    • Power off your Dell Inspiron 14-7437 before disassembling.
    • Remove the eight 4.5 mm screws on the back panel of the device using the Phillips 1 Screwdriver.
    • The two 4.5 mm screws in the center under the rubber mount cannot be removed, but can be loosened.
  2. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: passo 2, imagem 1 %32 Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: passo 2, imagem 2 %32
    • Pry open the back cover using a spudger and slide it along the under the cover.
  3. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement, Battery: passo 3, imagem 1 %32 Dell Inspiron 14-7437 Thermal Cooling Fan Replacement, Battery: passo 3, imagem 2 %32
    • Remove the two 2.5 mm screws holding the battery in place using the J000 Phillips Head Screwdriver.
  4. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: passo 4, imagem 1 %32
    • Disconnect the ribbon cables from the motherboard.
  5. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: passo 5, imagem 1 %32
    • Lift up and remove the Lithium-Polymer Battery.
  6. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement, Speaker: passo 6, imagem 1 %32
    • Disconnect wires from Motherboard by gently pulling up.
  7. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: passo 7, imagem 1 %32 Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: passo 7, imagem 2 %32 Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: passo 7, imagem 3 %32
    • Remove the speakers from the case.
  8. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement, Coin Cell Battery: passo 8, imagem 1 %32
    • Lift the coin cell battery wire, and carefully remove from motherboard.
    • There are little hooks that the wire is hooked under.
  9. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: passo 9, imagem 1 %32 Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: passo 9, imagem 2 %32
    • Remove the Coin-Cell Battery from the case.
    • There is a small amount of adhesive on the bottom of the coin cell battery.
  10. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement, Cooling Fan: passo 10, imagem 1 %32 Dell Inspiron 14-7437 Thermal Cooling Fan Replacement, Cooling Fan: passo 10, imagem 2 %32
    • Remove the two 2.5 mm screws using a J000 Phillips Head Screwdriver.
  11. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: passo 11, imagem 1 %32 Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: passo 11, imagem 2 %32
    • Pull up on the wire and remove the Cooling Fan.
  12. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement, Thermal-Cooling Assembly: passo 12, imagem 1 %32 Dell Inspiron 14-7437 Thermal Cooling Fan Replacement, Thermal-Cooling Assembly: passo 12, imagem 2 %32 Dell Inspiron 14-7437 Thermal Cooling Fan Replacement, Thermal-Cooling Assembly: passo 12, imagem 3 %32
    • Disconnect cables connected to the motherboard by lifting the flaps up and pulling out.
    • This is a ZIF connector and needs to have the side flaps flipped up before removal.
    • The ZIF connector has small clips that need to be pulled up before being pulled out.
  13. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: passo 13, imagem 1 %32 Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: passo 13, imagem 2 %32 Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: passo 13, imagem 3 %32
    • Remove the eight 2.5 mm screws using a J000 Phillips Head Screwdriver.
  14. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: passo 14, imagem 1 %32 Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: passo 14, imagem 2 %32
    • Flip the motherboard.
  15. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: passo 15, imagem 1 %32 Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: passo 15, imagem 2 %32
    • Loosen the three 2.5 mm screws using the J000 Phillips Head Screwdriver.
    • These three 2.5 mm screws cannot be removed from the Thermal Cooling assembly.
  16. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: passo 16, imagem 1 %32
    • Remove the Thermal-Cooling Assembly from the motherboard.
Conclusão
Katelyn Remy
Membro desde: 03/10/16
449 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team 7-8, Catania Spring 2016 Membro de UMass Dartmouth, Team 7-8, Catania Spring 2016
UMASSD-CATANIA-S16S7G8
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 6
Duração total: 1,063
