Introdução
The Cooling fan is used to remove heat from the laptop so it is not hot to the touch and does not burn the motherboard.
O que você precisa
Remove the eight 4.5 mm screws on the back panel of the device using the Phillips 1 Screwdriver.
Remove the two 2.5 mm screws holding the battery in place using the J000 Phillips Head Screwdriver.
Uma outra pessoa concluiu este guia.
