Ir para o conteúdo principal
Dell Inspiron 14-7437 Cooling Fan Replacement
O que você precisa
  1. Dell Inspiron 14-7437 Cooling Fan Replacement, Base Cover: passo 1, imagem 1 %32 Dell Inspiron 14-7437 Cooling Fan Replacement, Base Cover: passo 1, imagem 2 %32
    • Power off your Dell Inspiron 14-7437 before disassembling.
    • Remove the eight 4.5 mm screws on the back panel of the device using the Phillips 1 Screwdriver.
    • The two 4.5 mm screws in the center under the rubber mount cannot be removed, but can be loosened.
  2. Dell Inspiron 14-7437 Cooling Fan Replacement: passo 2, imagem 1 %32 Dell Inspiron 14-7437 Cooling Fan Replacement: passo 2, imagem 2 %32
    • Pry open the back cover using a spudger and slide it along the under the cover.
  3. Dell Inspiron 14-7437 Cooling Fan Replacement, Battery: passo 3, imagem 1 %32 Dell Inspiron 14-7437 Cooling Fan Replacement, Battery: passo 3, imagem 2 %32
    • Remove the two 2.5 mm screws holding the battery in place using the J000 Phillips Head Screwdriver.
  4. Dell Inspiron 14-7437 Cooling Fan Replacement: passo 4, imagem 1 %32
    • Disconnect the ribbon cables from the motherboard.
  5. Dell Inspiron 14-7437 Cooling Fan Replacement: passo 5, imagem 1 %32
    • Lift up and remove the Lithium-Polymer Battery.
  6. Dell Inspiron 14-7437 Cooling Fan Replacement, Cooling Fan: passo 6, imagem 1 %32 Dell Inspiron 14-7437 Cooling Fan Replacement, Cooling Fan: passo 6, imagem 2 %32
    • Remove the two 2.5 mm screws using a J000 Phillips Head Screwdriver.
  7. Dell Inspiron 14-7437 Cooling Fan Replacement: passo 7, imagem 1 %32 Dell Inspiron 14-7437 Cooling Fan Replacement: passo 7, imagem 2 %32
    • Pull up on the wire and remove the Cooling Fan.
Conclusão
Uma outra pessoa concluiu este guia.
Katelyn Remy
Membro desde: 03/10/16
449 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team 7-8, Catania Spring 2016 Membro de UMass Dartmouth, Team 7-8, Catania Spring 2016
UMASSD-CATANIA-S16S7G8
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 741
