Introdução
The Lithium-Polymer Battery in this laptop is long lasting but if it were to stop holding a charge then replacing it is simple and fast.
O que você precisa
Remove the eight 4.5 mm screws on the back panel of the device using the Phillips 1 Screwdriver.
Remove the two 2.5 mm screws holding the battery in place using the J000 Phillips Head Screwdriver.
3 outras pessoas executaram este guia.
