Ir para o conteúdo principal
Dell Inspiron 14-5447 Fan Replacement
O que você precisa
  1. Dell Inspiron 14-5447 Fan Replacement, Battery: passo 1, imagem 1 %32
    • Flip the laptop upside down to access the battery.
  2. Dell Inspiron 14-5447 Fan Replacement: passo 2, imagem 1 %32 Dell Inspiron 14-5447 Fan Replacement: passo 2, imagem 2 %32
    • Remove the two black 5.70mm Phillips#0 screws on the case's back.
    • Insert a plastic opening tool into the small slit, centered between the removed screws, and pry open the back cover
  3. Dell Inspiron 14-5447 Fan Replacement: passo 3, imagem 1 %32 Dell Inspiron 14-5447 Fan Replacement: passo 3, imagem 2 %32
    • Remove the two 5.70mm Phillips #0 screws that secure the battery in place on its left side .
    • Treat the battery with care - puncturing or bending may cause damage to the battery and may result in fire or injury.
  4. Dell Inspiron 14-5447 Fan Replacement: passo 4, imagem 1 %32 Dell Inspiron 14-5447 Fan Replacement: passo 4, imagem 2 %32
    • Use the black, plastic flap on the left side to pull the battery out.
    • Slowly lift the flap up and the battery should slide out.
  5. Dell Inspiron 14-5447 Fan Replacement, Fan: passo 5, imagem 1 %32
    • Locate the fan system in the top right corner.
  6. Dell Inspiron 14-5447 Fan Replacement: passo 6, imagem 1 %32 Dell Inspiron 14-5447 Fan Replacement: passo 6, imagem 2 %32
    • Look along the wide line of white cable until you find the tab insert.
    • Remove the thick white cable crossing over the fan, using the blue spudger shown, to flip the securing flap holding down the cable.
  7. Dell Inspiron 14-5447 Fan Replacement: passo 7, imagem 1 %32 Dell Inspiron 14-5447 Fan Replacement: passo 7, imagem 2 %32
    • Move the cable over to the side to reveal the fan screws.
    • Remove the two black 5.70 mm screws from the fan.
  8. Dell Inspiron 14-5447 Fan Replacement: passo 8, imagem 1 %32 Dell Inspiron 14-5447 Fan Replacement: passo 8, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use tweezers to remove the small cable attached to the fan.
  9. Dell Inspiron 14-5447 Fan Replacement: passo 9, imagem 1 %32 Dell Inspiron 14-5447 Fan Replacement: passo 9, imagem 2 %32
    • Using the opening tool, pry the fan out.
    • Remove the fan slowly to prevent damage to any wires or cables connected to the device.
  10. Dell Inspiron 14-5447 Fan Replacement: passo 10, imagem 1 %32
    • Now that the fan is removed, be sure to clean the area under the fan to prevent overheating.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 7
Duração total: 812
