Ir para o conteúdo principal
Dell Inspiron 14-5447 Battery Replacement
O que você precisa
  1. Dell Inspiron 14-5447 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Flip the laptop upside down to access the battery.
  2. Dell Inspiron 14-5447 Battery Replacement: passo 2, imagem 1 %32 Dell Inspiron 14-5447 Battery Replacement: passo 2, imagem 2 %32
    • Remove the two black 5.70mm Phillips#0 screws on the case's back.
    • Insert a plastic opening tool into the small slit, centered between the removed screws, and pry open the back cover
  3. Dell Inspiron 14-5447 Battery Replacement: passo 3, imagem 1 %32 Dell Inspiron 14-5447 Battery Replacement: passo 3, imagem 2 %32
    • Remove the two 5.70mm Phillips #0 screws that secure the battery in place on its left side .
    • Treat the battery with care - puncturing or bending may cause damage to the battery and may result in fire or injury.
  4. Dell Inspiron 14-5447 Battery Replacement: passo 4, imagem 1 %32 Dell Inspiron 14-5447 Battery Replacement: passo 4, imagem 2 %32
    • Use the black, plastic flap on the left side to pull the battery out.
    • Slowly lift the flap up and the battery should slide out.
Conclusão
4 outras pessoas executaram este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 14
Duração total: 3,032
