Ir para o conteúdo principal
Dell Inspiron 14-5415 Hard Drive Replacement
O que você precisa
  1. Dell Inspiron 14-5415 Hard Drive Replacement, Back Cover: passo 1, imagem 1 %32
    • Close the lid and turn the laptop over to access the back cover.
  2. Dell Inspiron 14-5415 Hard Drive Replacement: passo 2, imagem 1 %32
    • Remove the five 4 mm screws from the back of the laptop using a Phillips #0 screwdriver.
    • Loosen the two remaining captive screws using a Phillips #0 screwdriver.
    • Captive screws tend to have a slightly larger head than normal screws, so it is important to use the correct size screwdriver to avoid damaging the screw or the device.
  3. Dell Inspiron 14-5415 Hard Drive Replacement, Hard Drive: passo 3, imagem 1 %32 Dell Inspiron 14-5415 Hard Drive Replacement, Hard Drive: passo 3, imagem 2 %32
    • Remove the screw from the hard drive using a Phillips #00 screwdriver.
  4. Dell Inspiron 14-5415 Hard Drive Replacement: passo 4, imagem 1 %32
    • Carefully pull the hard drive out of its position.
    • Be sure to handle the hard drive with care. It should not need to be pulled hard to remove.
Conclusão
Ilana Ek-Adler
Membro desde: 02/09/23
85 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 11
Duração total: 199
