Introdução
This step-by-step guide will show how to replace the RAM (Random Access Memory) stick in your Inspiron 14-3452 with a new one. All you need is a spudger and a screwdriver.
Peças
Não são necessárias peças.
  1. Remove the battery by sliding the battery release latch to the left. Pull the entire battery away from the backing.
    • Remove the battery by sliding the battery release latch to the left.
    • Pull the entire battery away from the backing.
  2. Ensure that the laptop is completely turned off and the battery is removed.
    • Ensure that the laptop is completely turned off and the battery is removed.
    • Remove the two Phillips Head 5 mm #0 screws holding the backing in place.
  3. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  4. Pull the backing away from the laptop.
    • Pull the backing away from the laptop.
  5. Locate the blue RAM chip sitting in the RAM bay.
    • Locate the blue RAM chip sitting in the RAM bay.
    • Use your fingertips to pry apart the white RAM securing-clips on each side of the memory-module slot until the RAM chip pops up.
  6. Pull the RAM chip away from the memory-module slot.
    • Pull the RAM chip away from the memory-module slot.
    • The RAM chip is now fully detached and ready to be replaced.
Conclusão
Alec Siegel
535 reputação
4 Guides authored
Equipe
Baylor, Team S2-G2, Johnson Spring 2018 Membro de Baylor, Team S2-G2, Johnson Spring 2018
BU-JOHNSON-S18S2G2
3 Membros
5 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 10
Todo: 134
