Ir para o conteúdo principal
Dell Inspiron 14-3452 Random Access Memory (RAM) Replacement
O que você precisa
  1. Dell Inspiron 14-3452 Random Access Memory (RAM) Replacement, Battery: passo 1, imagem 1 %32 Dell Inspiron 14-3452 Random Access Memory (RAM) Replacement, Battery: passo 1, imagem 2 %32
    • Remove the battery by sliding the battery release latch to the left.
    • Pull the entire battery away from the backing.
  2. Dell Inspiron 14-3452 Random Access Memory (RAM) Replacement, Random Access Memory (RAM): passo 2, imagem 1 %32
    • Ensure that the laptop is completely turned off and the battery is removed.
    • Remove the two Phillips Head 5 mm #0 screws holding the backing in place.
  3. Dell Inspiron 14-3452 Random Access Memory (RAM) Replacement: passo 3, imagem 1 %32
    • Pull the backing away from the laptop.
  4. Dell Inspiron 14-3452 Random Access Memory (RAM) Replacement: passo 4, imagem 1 %32
    • Locate the blue RAM chip sitting in the RAM bay.
    • Use your fingertips to pry apart the white RAM securing-clips on each side of the memory-module slot until the RAM chip pops up.
  5. Dell Inspiron 14-3452 Random Access Memory (RAM) Replacement: passo 5, imagem 1 %32
    • Pull the RAM chip away from the memory-module slot.
    • The RAM chip is now fully detached and ready to be replaced.
Conclusão
Alec Siegel
Membro desde: 01/30/18
598 Reputação
Autoria de 4 guias
Equipe
Baylor, Team S2-G2, Johnson Spring 2018 Membro de Baylor, Team S2-G2, Johnson Spring 2018
BU-JOHNSON-S18S2G2
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 10
Duração total: 770
