Introdução
The motherboard functions as a central part of the laptop. Replacing the motherboard with a new one is an involved process, so we will walk you through each step of the process. All the tools needed is a screwdriver and a plastic spudger. Tweezers are optional.
Ferramentas
Peças
Não são necessárias peças.
Remove the battery by sliding the battery release latch to the left.
Pull the entire battery away from the backing.
Remove the two Phillips Head 5 mm #0 screws holding the backing in place.
Remove the ten Phillips Head 5 mm #0 screws from the computer backing.
Remove the one Phillips Head 3 mm #0 screw from the computer backing.
Uma outra pessoa concluiu este guia.
Um comentário
BEFORE REMOVING TOP CASE: There are screws under the keyboard and one silver screw under the battery that have to be removed. This guide forgot to mention that.
