Ir para o conteúdo principal
Dell Inspiron 14 N4050 Hard Drive Replacement
O que você precisa
  1. Dell Inspiron 14 N4050 Hard Drive Replacement, Sliding the Hard-Drive Assembly: passo 1, imagem 1 %32
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in "Before You Begin".
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Slide the hard-drive assembly to the left to disconnect it from the connector on the system board.
  2. Dell Inspiron 14 N4050 Hard Drive Replacement, Lifting the Hard-Drive Assembly: passo 2, imagem 1 %32
    • Lift the hard-drive assembly out of the computer base.
  3. Dell Inspiron 14 N4050 Hard Drive Replacement, Remove the Screws: passo 3, imagem 1 %32
    • Remove the two screws that secure the hard-drive bracket to the hard drive.
  4. Dell Inspiron 14 N4050 Hard Drive Replacement, Lifting the Hard-Drive Bracket: passo 4, imagem 1 %32
    • Lift the hard-drive bracket away from the hard drive.
  5. Dell Inspiron 14 N4050 Hard Drive Replacement, Placing the Hard-Drive Bracket: passo 5, imagem 1 %32
    • Place the hard-drive bracket on the NEW hard drive.
  6. Dell Inspiron 14 N4050 Hard Drive Replacement, Replace the Screws: passo 6, imagem 1 %32
    • Replace the two screws that secure the hard-drive bracket to the hard drive.
  7. Dell Inspiron 14 N4050 Hard Drive Replacement, Placing the Hard-Drive Assembly: passo 7, imagem 1 %32
    • Place the hard-drive assembly on the computer base.
  8. Dell Inspiron 14 N4050 Hard Drive Replacement, Push the Hard Drive Assembly: passo 8, imagem 1 %32
    • Push the hard-drive assembly towards the right to connect it to the connector on the system board.
Linha de Chegada
Terrence15
Membro desde: 12/18/17
79.091 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.985 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 1,567
