Introdução
In this guide, we will be showing you how to remove and replace the Hard Drive.
O que você precisa
Slide the hard-drive assembly to the left to disconnect it from the connector on the system board.
Lift the hard-drive assembly out of the computer base.
Remove the two screws that secure the hard-drive bracket to the hard drive.
Replace the two screws that secure the hard-drive bracket to the hard drive.
Push the hard-drive assembly towards the right to connect it to the connector on the system board.
Quase terminado!
Linha de Chegada
