Introdução
In this guide, we will be showing you how to remove and replace the Hard Drive.
Peças
Não são necessárias peças.
  1. WARNING: Before working inside your computer, read the safety information  that shipped with your computer. Follow the instructions in "Before You Begin".
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in "Before You Begin".
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
    • Slide the hard-drive assembly to the left to disconnect it from the connector on the system board.
  2. Lift the hard-drive assembly out of the computer base.
    • Lift the hard-drive assembly out of the computer base.
  3. Remove the two screws that secure the hard-drive bracket to the hard  drive.
    • Remove the two screws that secure the hard-drive bracket to the hard drive.
  4. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  5. Place the hard-drive bracket on the NEW hard drive. Place the hard-drive bracket on the NEW hard drive.
    • Place the hard-drive bracket on the NEW hard drive.
  6. Replace the two screws that secure the hard-drive bracket to the hard  drive.
    • Replace the two screws that secure the hard-drive bracket to the hard drive.
  7. Place the hard-drive assembly on the computer base.
    • Place the hard-drive assembly on the computer base.
  8. Push the hard-drive assembly towards the right to connect it to the  connector on the system board.
    • Push the hard-drive assembly towards the right to connect it to the connector on the system board.
Linha de Chegada
Terrence15
70.274 reputação
442 Guides authored
Equipe
Informative Technologies Inc. Membro de Informative Technologies Inc.
Community
15 Membros
925 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Todo: 23
