Ir para o conteúdo principal
Dell Inspiron 14 M4040 Display Assembly Replacement
O que você precisa
  1. Dell Inspiron 14 M4040 Display Assembly Replacement, Disconnecting the Display Cable: passo 1, imagem 1 %32
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Disconnect the display cable from the connector on the system board.
  2. Dell Inspiron 14 M4040 Display Assembly Replacement, Disconnect the Cables: passo 2, imagem 1 %32
    • Disconnect the Mini-Card antenna cables from the connectors on the Mini-Card.
  3. Dell Inspiron 14 M4040 Display Assembly Replacement, Remove the Cables: passo 3, imagem 1 %32
    • Make a note of the display cable and Mini-Card antenna cables routing and remove the cables from the routing guides.
  4. Dell Inspiron 14 M4040 Display Assembly Replacement, Remove the Screws: passo 4, imagem 1 %32
    • Remove the two screws that secure the display assembly to the computer base.
  5. Dell Inspiron 14 M4040 Display Assembly Replacement, Removing the Display Assembly: passo 5, imagem 1 %32
    • Lift and remove the display assembly out of the computer base.
  6. Dell Inspiron 14 M4040 Display Assembly Replacement, Placing the Display Assembly: passo 6, imagem 1 %32
    • Place the NEW display assembly in position and replace the two screws that secure the display assembly to the computer base.
  7. Dell Inspiron 14 M4040 Display Assembly Replacement, Routing the Cable: passo 7, imagem 1 %32
    • Route the display cable and Mini-Card antenna cables through the routing guides.
  8. Dell Inspiron 14 M4040 Display Assembly Replacement, Connect the Display Cable: passo 8, imagem 1 %32
    • Connect the display cable to the connector on the system board.
Linha de Chegada
Terrence15
Membro desde: 12/18/17
79.091 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.985 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 76
