Ir para o conteúdo principal
Dell Inspiron 14 M4010 Hard Drive Replacement
O que você precisa
  1. Dell Inspiron 14 M4010 Hard Drive Replacement, Remove the Screws: passo 1, imagem 1 %32
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • WARNING: If you remove the hard drive from the computer when the drive is hot, do not touch the metal housing of the hard drive.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
    • Remove the two screws that secure the hard-drive assembly to the system board.
  2. Dell Inspiron 14 M4010 Hard Drive Replacement, Disconnecting the Hard-Drive Assembly: passo 2, imagem 1 %32
    • Slide the hard-drive assembly to disconnect it from the connector on the system board.
  3. Dell Inspiron 14 M4010 Hard Drive Replacement, Lifting the Hard-Drive Assembly: passo 3, imagem 1 %32
    • Lift the hard-drive assembly away from the system board.
  4. Dell Inspiron 14 M4010 Hard Drive Replacement, Remove the Screws: passo 4, imagem 1 %32
    • Remove the four screws that secure the hard-drive bracket to the hard drive.
  5. Dell Inspiron 14 M4010 Hard Drive Replacement, Lifting the Hard-Drive Bracket: passo 5, imagem 1 %32
    • Lift the hard-drive bracket off the hard drive.
  6. Dell Inspiron 14 M4010 Hard Drive Replacement, Align the Screws: passo 6, imagem 1 %32
    • Align the screw holes on the hard-drive bracket with the screw holes on the NEW hard drive and replace the four screws.
  7. Dell Inspiron 14 M4010 Hard Drive Replacement, Connecting the Hard-Drive Assembly: passo 7, imagem 1 %32
    • Slide and push the hard-drive assembly to connect it to connector on the system board.
  8. Dell Inspiron 14 M4010 Hard Drive Replacement, Replace the Screws: passo 8, imagem 1 %32
    • Replace the two screws that secure the hard-drive assembly to the system board.
Linha de Chegada
Terrence15
Membro desde: 12/18/17
79.121 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.985 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 53
