Ir para o conteúdo principal
Dell Inspiron 14 M4010 Display Assembly Replacement
O que você precisa
  1. Dell Inspiron 14 M4010 Display Assembly Replacement, Remove the Screws: passo 1, imagem 1 %32
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • Remove the two screws that secure the display assembly to the computer base.
  2. Dell Inspiron 14 M4010 Display Assembly Replacement, Open the Display: passo 2, imagem 1 %32
    • Turn the computer over and open the display as far as possible.
  3. Dell Inspiron 14 M4010 Display Assembly Replacement, Disconnecting the Display Cable: passo 3, imagem 1 %32 Dell Inspiron 14 M4010 Display Assembly Replacement, Disconnecting the Display Cable: passo 3, imagem 2 %32
    • Disconnect the display cable from the connector on the system board, and remove the display cable grounding screw.
  4. Dell Inspiron 14 M4010 Display Assembly Replacement, Remove the Cables: passo 4, imagem 1 %32
    • Make a note of the Mini-Card antenna cables and display cable routing and remove the cables from the routing guides.
  5. Dell Inspiron 14 M4010 Display Assembly Replacement, Remove the Screws: passo 5, imagem 1 %32
    • Hold the display assembly in place and remove the four screws that secure the display assembly to the computer base.
  6. Dell Inspiron 14 M4010 Display Assembly Replacement, Removing the Display Assembly: passo 6, imagem 1 %32
    • Lift and remove the display assembly out of the computer base.
  7. Dell Inspiron 14 M4010 Display Assembly Replacement, Placing the Display Assembly: passo 7, imagem 1 %32
    • Place the NEW display assembly in position and replace the four screws (two on each side) that secure the display assembly to the computer base.
  8. Dell Inspiron 14 M4010 Display Assembly Replacement, Routing the Cables: passo 8, imagem 1 %32
    • Route the Mini-Card antenna cables and display cable through the routing guides.
  9. Dell Inspiron 14 M4010 Display Assembly Replacement, Replace the Display Cable: passo 9, imagem 1 %32
    • Connect the display cable to the connector on the system board, and replace the display cable grounding screw.
  10. Dell Inspiron 14 M4010 Display Assembly Replacement, Close the Display: passo 10, imagem 1 %32
    • Close the display and turn the computer over.
  11. Dell Inspiron 14 M4010 Display Assembly Replacement, Replace the Screws: passo 11, imagem 1 %32
    • Replace the two screws that secure the display assembly to the computer base.
    • CAUTION: Before turning on the computer, replace all screws and ensure that no stray screws remain inside the computer. Failure to do so may result in damage to the computer.
Linha de Chegada
Terrence15
Membro desde: 12/18/17
79.121 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.985 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 69
