Ir para o conteúdo principal
Dell Inspiron 14 Gaming 7467 Solid-State Drive Replacement
O que você precisa
  1. Dell Inspiron 14 Gaming 7467 Solid-State Drive Replacement, Remove the Screw: passo 1, imagem 1 %32
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • CAUTION: Solid-state drives are fragile. Exercise care when handling the solid-state drive.
    • CAUTION: To avoid data loss, do not remove the solid-state drive while the computer is in sleep or on state.
    • Remove the screw (M2x3) that secures the solid-state drive to the computer base.
  2. Dell Inspiron 14 Gaming 7467 Solid-State Drive Replacement, Remove the Solid-State Drive: passo 2, imagem 1 %32
    • Slide and remove the solid-state drive from the solid-state drive slot.
  3. Dell Inspiron 14 Gaming 7467 Solid-State Drive Replacement, Align the Notch: passo 3, imagem 1 %32
    • Align the notch on the solid-state drive with the tab on the solid-state drive slot, and slide the solid-state drive into the solid-state drive slot.
  4. Dell Inspiron 14 Gaming 7467 Solid-State Drive Replacement, Align the Hole: passo 4, imagem 1 %32
    • Press the other end of the solid-state drive to align the screw hole on the solid-state drive with the screw hole on the computer base.
  5. Dell Inspiron 14 Gaming 7467 Solid-State Drive Replacement, Replace the Screw: passo 5, imagem 1 %32
    • Replace the screw (M2x3) that secures the solid-state drive to the computer base.
Linha de Chegada
Terrence15
Membro desde: 12/18/17
78.818 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.984 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 74
