Ir para o conteúdo principal
Dell Inspiron 14 Gaming 7466 Display Assembly Replacement
O que você precisa
  1. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Disconnecting the Camera Cable: passo 1, imagem 1 %32
  2. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Peeling the Camera Cable: passo 2, imagem 1 %32
    • Peel off the camera cable from the computer base.
  3. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Remove the Antenna Cables: passo 3, imagem 1 %32
    • Remove the antenna cables from the routing guides on the computer base.
  4. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Remove the Screw: passo 4, imagem 1 %32
    • Remove the screw (M2x3) that secures the display-cable bracket to the system board.
  5. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Lifting the Display Cable Bracket: passo 5, imagem 1 %32
    • Lift the display-cable bracket off the system board.
  6. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Disconnecting the Display Cable: passo 6, imagem 1 %32
    • Using the pull-tab, disconnect the display cable from the system board.
  7. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Peel off the Display Cable: passo 7, imagem 1 %32
    • Peel off the display cable from the computer base.
  8. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Remove the Screws: passo 8, imagem 1 %32
    • Remove the two screws (M2x3) that secure the display assembly to the computer base.
  9. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Remove the Screws: passo 9, imagem 1 %32
    • Remove the two screws (M2.5x5) that secure the display assembly to the computer base.
  10. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Open the Display: passo 10, imagem 1 %32
    • Turn the computer over and open the display.
  11. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Remove the Screws: passo 11, imagem 1 %32
  12. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Lifting the Display Assembly: passo 12, imagem 1 %32
    • Lift the display assembly off the computer base.
  13. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Align the Screw Holes: passo 13, imagem 1 %32
    • Align the screw holes on the NEW display assembly with the screw holes on the computer base.
  14. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Replace the Screws: passo 14, imagem 1 %32
    • Replace the two screws (M2.5x5) that secure the display assembly to the computer base.
  15. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Replace the Screws: passo 15, imagem 1 %32
    • Close the display and turn the computer over.
  16. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Replace the Screws: passo 16, imagem 1 %32
    • Replace the two screws (M2x3) that secure the display assembly to the computer base.
  17. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Adhering the Cables: passo 17, imagem 1 %32
    • Adhere the display cable and the camera cable to the computer base.
  18. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Connect the Display Cable: passo 18, imagem 1 %32
    • Connect the display cable and camera cable to the system board.
  19. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Align the Screw Hole: passo 19, imagem 1 %32
    • Align the screw hole on the display-cable bracket with the screw hole on the system board.
  20. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Replace the Screw: passo 20, imagem 1 %32
    • Replace the screw (M2x3) that secures the display cable bracket to the system board.
Linha de Chegada
Terrence15
Membro desde: 12/18/17
79.309 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.984 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 122
