Ir para o conteúdo principal
Dell Inspiron 14 5443 Hard Drive Replacement
O que você precisa
  1. Dell Inspiron 14 5443 Hard Drive Replacement, Removing screws: passo 1, imagem 1 %32
    • Remove the screws that secure the hard-drive assembly to the base frame.
  2. Dell Inspiron 14 5443 Hard Drive Replacement, Gently Lift Hard-Drive: passo 2, imagem 1 %32
    • Gently lift the hard-drive assembly out of the base frame and disconnect the hard-drive cable from the hard drive.
  3. Dell Inspiron 14 5443 Hard Drive Replacement, Removing Screws From Bracket: passo 3, imagem 1 %32
    • Remove the screws that secure the hard-drive bracket to the hard drive.
  4. Dell Inspiron 14 5443 Hard Drive Replacement, Lifting Bracket: passo 4, imagem 1 %32
    • Lift the hard-drive bracket off the hard drive
  5. Dell Inspiron 14 5443 Hard Drive Replacement, Placing Bracket: passo 5, imagem 1 %32
    • Place the hard-drive bracket on the NEW hard drive.
  6. Dell Inspiron 14 5443 Hard Drive Replacement, Aligning the Screws: passo 6, imagem 1 %32
    • Align the screw holes on the hard drive-bracket with the screw holes on the hard drive.
  7. Dell Inspiron 14 5443 Hard Drive Replacement, Replace the Screws: passo 7, imagem 1 %32
    • Replace the screws that secure the hard-drive bracket to the hard drive.
  8. Dell Inspiron 14 5443 Hard Drive Replacement, Connecting Hard-Drive To Cable: passo 8, imagem 1 %32
    • Connect the hard-drive cable to the hard drive.
  9. Dell Inspiron 14 5443 Hard Drive Replacement, Placing the Hard-Drive: passo 9, imagem 1 %32
    • Place the hard-drive assembly in the base frame and align the screw holes on the hard-drive assembly with the screw holes on the base frame.
  10. Dell Inspiron 14 5443 Hard Drive Replacement, Securing the Screws: passo 10, imagem 1 %32
    • Replace the screws that secure the hard-drive assembly to the base frame.
Linha de Chegada
Uma outra pessoa concluiu este guia.
darrius
Membro desde: 03/26/18
5.213 Reputação
Autoria de 30 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.985 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 230
