Ir para o conteúdo principal
Dell Inspiron 14 3468 Hard-Drive Replacement
O que você precisa
  1. Dell Inspiron 14 3468 Hard-Drive Replacement, Removing the Screws: passo 1, imagem 1 %32
    • Remove the screws that secure the hard-drive assembly to the computer base.
  2. Dell Inspiron 14 3468 Hard-Drive Replacement, Disconnecting the Hard-Drive Cable: passo 2, imagem 1 %32
    • Open the latch and disconnect the hard-drive cable from the system board.
  3. Dell Inspiron 14 3468 Hard-Drive Replacement, Lifting the Hard-Drive: passo 3, imagem 1 %32
    • Lift the hard-drive assembly off the computer base.
  4. Dell Inspiron 14 3468 Hard-Drive Replacement, Removing the Screws: passo 4, imagem 1 %32
    • Remove the screws that secure the hard-drive bracket to the hard drive.
  5. Dell Inspiron 14 3468 Hard-Drive Replacement, Lifting the Hard-Drive  Bracket: passo 5, imagem 1 %32
    • Lift the hard-drive bracket off the hard drive.
  6. Dell Inspiron 14 3468 Hard-Drive Replacement, Disconnecting the Interposer: passo 6, imagem 1 %32
    • Disconnect the interposer from the hard drive.
  7. Dell Inspiron 14 3468 Hard-Drive Replacement, Connecting the Interposer: passo 7, imagem 1 %32
    • Connect the interposer to the NEW hard drive.
  8. Dell Inspiron 14 3468 Hard-Drive Replacement, Align the Screws: passo 8, imagem 1 %32
    • Align the screw holes on the hard-drive bracket with the screw holes on the hard drive.
  9. Dell Inspiron 14 3468 Hard-Drive Replacement, Securing the Screws: passo 9, imagem 1 %32
    • Replace the screws that secure the hard-drive bracket to the hard drive.
  10. Dell Inspiron 14 3468 Hard-Drive Replacement, Align the Screw Holes: passo 10, imagem 1 %32
    • Align the screw holes on the hard-drive assembly with the screw holes on the computer base.
  11. Dell Inspiron 14 3468 Hard-Drive Replacement, Securing the Screws: passo 11, imagem 1 %32
    • Replace the screws that secure the hard-drive assembly to the computer base.
  12. Dell Inspiron 14 3468 Hard-Drive Replacement, Sliding the Hard-Drive Cable: passo 12, imagem 1 %32
    • Slide the hard-drive cable into the system board and close the latch to secure the cable.
Linha de Chegada
Uma outra pessoa concluiu este guia.
darrius
Membro desde: 03/26/18
5.213 Reputação
Autoria de 30 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.989 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 155
