Ir para o conteúdo principal
Dell Inspiron 14 3467 Hard-Drive Replacement
O que você precisa
  1. Dell Inspiron 14 3467 Hard-Drive  Replacement, Disconnecting The Hard-Drive: passo 1, imagem 1 %32
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in [http://n Before working inside your computer.]
    • CAUTION: Hard drives are fragile. Exercise care when handling the hard drive.
    • Open the latch, and disconnect the hard-drive cable from the connector on the system board.
  2. Dell Inspiron 14 3467 Hard-Drive  Replacement, Removing The Two Screws: passo 2, imagem 1 %32
    • Remove the two screws (M2x3) that secure the hard-drive assembly to the palm-rest assembly.
  3. Dell Inspiron 14 3467 Hard-Drive  Replacement, Lifting The Hard-Drive: passo 3, imagem 1 %32
    • Lift the hard-drive assembly along with its cable off the palm-rest assembly.
  4. Dell Inspiron 14 3467 Hard-Drive  Replacement, Removing The Four Screws: passo 4, imagem 1 %32
    • Remove the four screws (M3x3) that secure the hard-drive bracket to the harddrive assembly.
  5. Dell Inspiron 14 3467 Hard-Drive  Replacement, Removing The Hard-Drive Bracket: passo 5, imagem 1 %32
    • Lift the hard-drive assembly off the hard-drive bracket.
  6. Dell Inspiron 14 3467 Hard-Drive  Replacement, Disconnecting The Interposer: passo 6, imagem 1 %32
    • Disconnect the interposer from the hard drive.
  7. Dell Inspiron 14 3467 Hard-Drive  Replacement, Connecting The Interposer: passo 7, imagem 1 %32
    • Connect the interposer to the NEW hard drive
  8. Dell Inspiron 14 3467 Hard-Drive  Replacement, Aligning The Screws: passo 8, imagem 1 %32
    • Align the screw holes on the hard-drive bracket with the screw holes on the hard-drive assembly.
  9. Dell Inspiron 14 3467 Hard-Drive  Replacement, Screwing The Bracket To Hard-Drive: passo 9, imagem 1 %32
    • Replace the four screws (M3x3) that secure the hard-drive bracket to the harddrive assembly.
  10. Dell Inspiron 14 3467 Hard-Drive  Replacement, Securing To Hard-Drive Assembly: passo 10, imagem 1 %32
    • Replace the two screws (M2x3) that secure the hard-drive assembly to the palm-rest assembly.
Conclusão
darrius
Membro desde: 03/26/18
5.213 Reputação
Autoria de 30 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 43
Autoria de 1.985 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 16
Duração total: 3,305
