Ir para o conteúdo principal
Dell Inspiron 14 3467 Battery Replacement
O que você precisa
  1. Dell Inspiron 14 3467 Battery Replacement, Turning over the Computer: passo 1, imagem 1 %32
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Turn the computer over and slide the battery latch to the unlock position. You can hear a click sound when the battery is unlocked.
  2. Dell Inspiron 14 3467 Battery Replacement, Lifting the Battery: passo 2, imagem 1 %32
    • Using your fingertips, lift the battery at an angle and remove the battery off the computer base.
  3. Dell Inspiron 14 3467 Battery Replacement, Grounding the System Board: passo 3, imagem 1 %32
    • Turn the computer over, open the display, and press the power button for five seconds to ground the system board.
  4. Dell Inspiron 14 3467 Battery Replacement, Sliding the Battery: passo 4, imagem 1 %32
    • Slide the tabs on the battery into the slots on the battery bay and snap the battery into place.
Linha de Chegada
darrius
Membro desde: 03/26/18
5.213 Reputação
Autoria de 30 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 43
Autoria de 1.985 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 17
Duração total: 768
