Ir para o conteúdo principal
Dell Inspiron 14 3467 Base Cover Replacement
O que você precisa
  1. Dell Inspiron 14 3467 Base Cover Replacement, Turning over the Computer: passo 1, imagem 1 %32
  2. Dell Inspiron 14 3467 Base Cover Replacement, Remove the Screws: passo 2, imagem 1 %32
    • Remove the eight screws that secure the base cover to the palm-rest assembly.
  3. Dell Inspiron 14 3467 Base Cover Replacement, Removing the Screws: passo 3, imagem 1 %32
    • Remove the two screws that secure the base cover to the palm-rest assembly.
  4. Dell Inspiron 14 3467 Base Cover Replacement, Removing the screws: passo 4, imagem 1 %32
    • Remove the three screws that secure the base cover to the palm-rest assembly.
  5. Dell Inspiron 14 3467 Base Cover Replacement, Turning the Computer over: passo 5, imagem 1 %32
    • Turn the computer over, and open the display.
  6. Dell Inspiron 14 3467 Base Cover Replacement, Removing the Screws: passo 6, imagem 1 %32
  7. Dell Inspiron 14 3467 Base Cover Replacement, Disconnecting the Optical-Drive Cable: passo 7, imagem 1 %32
    • Open the latch, and disconnect the optical-drive cable from the system board.
  8. Dell Inspiron 14 3467 Base Cover Replacement, Turning the Computer Over: passo 8, imagem 1 %32
    • Close the display, and turn the computer over
  9. Dell Inspiron 14 3467 Base Cover Replacement, Prying the Base Cover: passo 9, imagem 1 %32
    • Using a plastic scribe, pry the base cover off the palm-rest assembly.
  10. Dell Inspiron 14 3467 Base Cover Replacement, Lifting the Base Cover: passo 10, imagem 1 %32
    • Lift the base cover off the palm-rest assembly.
  11. Dell Inspiron 14 3467 Base Cover Replacement, Release the Optical-Drive Interposer: passo 11, imagem 1 %32
    • Release the optical-drive interposer from the tabs, and remove it from the base cover.
  12. Dell Inspiron 14 3467 Base Cover Replacement, Sliding the Optical-Drive: passo 12, imagem 1 %32
    • Slide the optical-drive interposer into the tabs on the NEW base cover and snap it into place.
  13. Dell Inspiron 14 3467 Base Cover Replacement, Placing the Base Cover: passo 13, imagem 1 %32
    • Place the base cover on the palm-rest assembly and route the optical-drive cable through the slot on the palm-rest assembly.
  14. Dell Inspiron 14 3467 Base Cover Replacement, Sliding the Tabs: passo 14, imagem 1 %32
    • Slide the tabs on the base cover into the slots on the palm-rest assembly, and snap the base cover into place.
  15. Dell Inspiron 14 3467 Base Cover Replacement, Sliding the Optical-Drive Cable: passo 15, imagem 1 %32
    • Slide the optical-drive cable into the connector on the system board and press down the latch to secure the cable.
  16. Dell Inspiron 14 3467 Base Cover Replacement, Placing the Screws: passo 16, imagem 1 %32
    • Replace the three screws (M2x5) that secure the base cover to the palm-rest assembly.
  17. Dell Inspiron 14 3467 Base Cover Replacement, Turning over the Computer: passo 17, imagem 1 %32
    • Close the display, and turn the computer over.
  18. Dell Inspiron 14 3467 Base Cover Replacement, Replacing the Screws: passo 18, imagem 1 %32
    • Replace the three screws (M2x2) that secure the base cover to the palm-rest assembly.
  19. Dell Inspiron 14 3467 Base Cover Replacement, Replacing the Screws: passo 19, imagem 1 %32
    • Replace the two screws (M2x5) that secure the base cover to the palm-rest assembly.
  20. Dell Inspiron 14 3467 Base Cover Replacement, Replacing the Screws: passo 20, imagem 1 %32
    • Replace the eight screws that secure the base cover to the palm-rest assembly.
Linha de Chegada
Uma outra pessoa concluiu este guia.
darrius
Membro desde: 03/26/18
5.213 Reputação
Autoria de 30 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.985 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 11
Duração total: 1,975
