Ir para o conteúdo principal
Dell Inspiron 14 3462 Display Assembly Replacement
O que você precisa
  1. Dell Inspiron 14 3462 Display Assembly Replacement, Peel the Tape: passo 1, imagem 1 %32
  2. Dell Inspiron 14 3462 Display Assembly Replacement, Disconnecting the Display Cable: passo 2, imagem 1 %32
    • Open the latch that secures the display cable into position.
    • Disconnect the display cable from the system board.
  3. Dell Inspiron 14 3462 Display Assembly Replacement, Remove the Antenna Cable: passo 3, imagem 1 %32
    • Note the antenna-cable routing, and remove the antenna cable from the routing guides on the palm-rest assembly.
  4. Dell Inspiron 14 3462 Display Assembly Replacement, Turn the Computer Over: passo 4, imagem 1 %32
    • Turn the computer over and open the display at an angle of 90 degrees.
    • Turn the computer over and place it on the edge of the table in a position that allows access to the screws on the display hinges.
  5. Dell Inspiron 14 3462 Display Assembly Replacement, Remove the Screws: passo 5, imagem 1 %32
    • Remove the three screws (M2.5x8) that secure the display-hinge brackets to the palm-rest assembly.
  6. Dell Inspiron 14 3462 Display Assembly Replacement, Lifting the Display Assembly: passo 6, imagem 1 %32
    • Carefully lift the display assembly from the palm-rest assembly.
  7. Dell Inspiron 14 3462 Display Assembly Replacement, Placing the Display Assembly: passo 7, imagem 1 %32
    • Carefully place the display assembly on a clean and flat surface.
  8. Dell Inspiron 14 3462 Display Assembly Replacement, Placing the Display Assembly: passo 8, imagem 1 %32
    • Place the NEW display assembly at the edge of the table.
  9. Dell Inspiron 14 3462 Display Assembly Replacement, Align the Screw Holes: passo 9, imagem 1 %32
    • Align the screw holes on the palm-rest assembly with the screw holes on the display hinges.
  10. Dell Inspiron 14 3462 Display Assembly Replacement, Replace the Screws: passo 10, imagem 1 %32
    • Replace the three screws (M2.5x8) that secure the display hinges to the palm-rest assembly.
  11. Dell Inspiron 14 3462 Display Assembly Replacement, Route the Cables: passo 11, imagem 1 %32
    • Route the antenna cables through the routing guides on the palm-rest assembly.
  12. Dell Inspiron 14 3462 Display Assembly Replacement, Connecting the Display Cable: passo 12, imagem 1 %32
    • Connect the display cable from the system board.
  13. Dell Inspiron 14 3462 Display Assembly Replacement, Close the Latch: passo 13, imagem 1 %32
    • Close the latch that secures the display cable to the system board.
  14. Dell Inspiron 14 3462 Display Assembly Replacement, Adhering the Tape: passo 14, imagem 1 %32
    • Adhere the tape that secures the display cable to the system board.
Linha de Chegada
Terrence15
Membro desde: 12/18/17
79.243 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.989 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 5
Duração total: 230
