Introdução
In this guide, we will show you how to remove and replace the Display Assembly.
O que você precisa
Open the latch that secures the display cable into position.
Disconnect the display cable from the system board.
Note the antenna-cable routing, and remove the antenna cable from the routing guides on the palm-rest assembly.
Turn the computer over and open the display at an angle of 90 degrees.
Turn the computer over and place it on the edge of the table in a position that allows access to the screws on the display hinges.
Remove the three screws (M2.5x8) that secure the display-hinge brackets to the palm-rest assembly.
Carefully lift the display assembly from the palm-rest assembly.
Carefully place the display assembly on a clean and flat surface.
Place the NEW display assembly at the edge of the table.
Align the screw holes on the palm-rest assembly with the screw holes on the display hinges.
Replace the three screws (M2.5x8) that secure the display hinges to the palm-rest assembly.
Route the antenna cables through the routing guides on the palm-rest assembly.
Adhere the tape that secures the display cable to the system board.
