Ir para o conteúdo principal
Dell Inspiron 14 3459 Hard Drive Replacement
O que você precisa
  1. Dell Inspiron 14 3459 Hard Drive Replacement, Remove the Screws: passo 1, imagem 1 %32
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • CAUTION: Hard drives are fragile. Exercise care when handling the hard drive.
    • Remove the screws that secure the hard-drive assembly to the computer base.
  2. Dell Inspiron 14 3459 Hard Drive Replacement, Disconnect the Hard Drive Cable: passo 2, imagem 1 %32 Dell Inspiron 14 3459 Hard Drive Replacement, Disconnect the Hard Drive Cable: passo 2, imagem 2 %32
    • Open the latch and disconnect the hard-drive cable from the system board.
  3. Dell Inspiron 14 3459 Hard Drive Replacement, Lifting the Hard-Drive Assembly: passo 3, imagem 1 %32
    • Lift the hard-drive assembly off the computer base.
  4. Dell Inspiron 14 3459 Hard Drive Replacement, Remove the Screws: passo 4, imagem 1 %32
    • Remove the screws that secure the hard-drive bracket to the hard drive.
  5. Dell Inspiron 14 3459 Hard Drive Replacement, Lifting the Hard-Drive Bracket: passo 5, imagem 1 %32
    • Lift the hard-drive bracket off the hard drive.
  6. Dell Inspiron 14 3459 Hard Drive Replacement, Disconnecting the Interposer: passo 6, imagem 1 %32
    • Disconnect the interposer from the hard drive.
  7. Dell Inspiron 14 3459 Hard Drive Replacement, Connecting the Interposer: passo 7, imagem 1 %32
    • Connect the interposer to the NEW hard drive.
  8. Dell Inspiron 14 3459 Hard Drive Replacement, Align the Screw Holes: passo 8, imagem 1 %32
    • Align the screw holes on the hard-drive bracket with the screw holes on the hard drive.
  9. Dell Inspiron 14 3459 Hard Drive Replacement, Replace the Screws: passo 9, imagem 1 %32
    • Replace the screws that secure the hard-drive bracket to the hard drive.
  10. Dell Inspiron 14 3459 Hard Drive Replacement, Align the Screw Holes: passo 10, imagem 1 %32
    • Align the screw holes on the hard-drive assembly with the screw holes on the computer base.
  11. Dell Inspiron 14 3459 Hard Drive Replacement, Replace the Screws: passo 11, imagem 1 %32
    • Replace the screws that secure the hard-drive assembly to the computer base.
  12. Dell Inspiron 14 3459 Hard Drive Replacement, Securing the Hard Drive Cable: passo 12, imagem 1 %32 Dell Inspiron 14 3459 Hard Drive Replacement, Securing the Hard Drive Cable: passo 12, imagem 2 %32
    • Slide the hard-drive cable into the system board and close the latch to secure the cable.
Linha de Chegada
Terrence15
Membro desde: 12/18/17
79.121 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.985 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 8
Duração total: 1,248
