Ir para o conteúdo principal
Dell Inspiron 13z N301z Hard-Drive Assembly Replacement
O que você precisa
  1. Dell Inspiron 13z N301z Hard-Drive Assembly Replacement, Removing the Screws: passo 1, imagem 1 %32
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Remove the four screws that secure the hard-drive assembly to the computer base.
  2. Dell Inspiron 13z N301z Hard-Drive Assembly Replacement, Lifting the Connector Latch: passo 2, imagem 1 %32
    • Lift the connector latch and pull the pull-tab to disconnect the hard-drive cable from the connector on the system board.
  3. Dell Inspiron 13z N301z Hard-Drive Assembly Replacement, Lifting the Hard-Drive Assembly: passo 3, imagem 1 %32
    • Lift the hard-drive assembly out of the computer base.
  4. Dell Inspiron 13z N301z Hard-Drive Assembly Replacement, Remove the Screws: passo 4, imagem 1 %32
    • Remove the four screws that secure the hard-drive bracket to the hard drive.
  5. Dell Inspiron 13z N301z Hard-Drive Assembly Replacement, Lifting the Hard Drive: passo 5, imagem 1 %32 Dell Inspiron 13z N301z Hard-Drive Assembly Replacement, Lifting the Hard Drive: passo 5, imagem 2 %32
    • Lift the hard drive out of the hard-drive bracket.
  6. Dell Inspiron 13z N301z Hard-Drive Assembly Replacement, Disconnecting the Interposer: passo 6, imagem 1 %32
    • Pull the interposer to disconnect it from the hard drive.
  7. Dell Inspiron 13z N301z Hard-Drive Assembly Replacement, Connecting the Interposer: passo 7, imagem 1 %32
    • Connect the interposer to the NEW hard drive.
  8. Dell Inspiron 13z N301z Hard-Drive Assembly Replacement, Placing the Hard-Drive: passo 8, imagem 1 %32 Dell Inspiron 13z N301z Hard-Drive Assembly Replacement, Placing the Hard-Drive: passo 8, imagem 2 %32
    • Place the hard drive in the hard-drive bracket.
  9. Dell Inspiron 13z N301z Hard-Drive Assembly Replacement, Replace the Screws: passo 9, imagem 1 %32
    • Replace the four screws the hard-drive bracket to the hard drive.
  10. Dell Inspiron 13z N301z Hard-Drive Assembly Replacement, Placing the Hard-Drive Assembly: passo 10, imagem 1 %32
    • Place the hard-drive assembly in the computer base.
  11. Dell Inspiron 13z N301z Hard-Drive Assembly Replacement, Sliding the Hard-Drive Cable: passo 11, imagem 1 %32
    • Slide the hard-drive cable into the connector on the system board and press down on the latch to secure the hard-drive cable.
  12. Dell Inspiron 13z N301z Hard-Drive Assembly Replacement, Replace the Screws: passo 12, imagem 1 %32
    • Replace the four screws that secure the hard-drive assembly to the computer base.
Linha de Chegada
Uma outra pessoa concluiu este guia.
Terrence15
Membro desde: 12/18/17
79.061 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.985 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 205
