Ir para o conteúdo principal
Dell Inspiron 13z 5323 Power button Replacement
O que você precisa
  1. Dell Inspiron 13z 5323 Power button Replacement, Power button: passo 1, imagem 1 %32 Dell Inspiron 13z 5323 Power button Replacement, Power button: passo 1, imagem 2 %32 Dell Inspiron 13z 5323 Power button Replacement, Power button: passo 1, imagem 3 %32
    • Remove nine screws from the bottom case.
    • Loosen the single captive screw on the base cover.
    • The screw in the base cover will stay inside the hole because it is held in by a small washer.
  2. Dell Inspiron 13z 5323 Power button Replacement: passo 2, imagem 1 %32 Dell Inspiron 13z 5323 Power button Replacement: passo 2, imagem 2 %32 Dell Inspiron 13z 5323 Power button Replacement: passo 2, imagem 3 %32
    • There are 3 slots on the top of the keyboard where you will have to use a thin tool, such as a small flathead screwdriver to push the tabs so the keyboard will pop out.
    • You will have to flip a small tab up where the ribbon connector goes into the insert, so the connector can be released and the keyboard can be removed.
  3. Dell Inspiron 13z 5323 Power button Replacement: passo 3, imagem 1 %32 Dell Inspiron 13z 5323 Power button Replacement: passo 3, imagem 2 %32 Dell Inspiron 13z 5323 Power button Replacement: passo 3, imagem 3 %32
    • Unscrew the highlighted screw and slide out the power button assembly.
    • Separate the palm rest from the base of the device using the blue separating tool. Before separating the palm rest from the device make sure to release all visible ribbon connectors.
    • Flip the palm rest over and you will notice the power button assembly in the top right corner of the palm rest.
Conclusão
David Gilleran
Membro desde: 03/08/17
201 Reputação
Autoria de 2 guias
Equipe
Um comentário
this guide has no descriptions on what is going feels incomplete.
Matthew Coughlin - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 225
