Ir para o conteúdo principal
Dell Inspiron 13z 5323 Hard Drive Replacement
O que você precisa
  1. Dell Inspiron 13z 5323 Hard Drive Replacement, Remove the Screws: passo 1, imagem 1 %32
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin".
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
    • Remove the screws that secure the hard-drive assembly to the computer base.
  2. Dell Inspiron 13z 5323 Hard Drive Replacement, Disconnecting the Hard-Drive Cable: passo 2, imagem 1 %32 Dell Inspiron 13z 5323 Hard Drive Replacement, Disconnecting the Hard-Drive Cable: passo 2, imagem 2 %32
    • Disconnect the hard-drive cable connector from the hard-drive assembly.
  3. Dell Inspiron 13z 5323 Hard Drive Replacement, Lifting the Hard-Drive Assembly: passo 3, imagem 1 %32
    • Lift the hard-drive assembly away from the computer base.
  4. Dell Inspiron 13z 5323 Hard Drive Replacement, Remove the Screws: passo 4, imagem 1 %32
    • Remove the screws that secure the hard-drive bracket to the hard drive.
  5. Dell Inspiron 13z 5323 Hard Drive Replacement, Lifting the Hard-Drive Bracket: passo 5, imagem 1 %32 Dell Inspiron 13z 5323 Hard Drive Replacement, Lifting the Hard-Drive Bracket: passo 5, imagem 2 %32
    • Lift the hard-drive bracket off the hard drive.
  6. Dell Inspiron 13z 5323 Hard Drive Replacement, Align the Screw Holes: passo 6, imagem 1 %32
    • Align the screw holes on the hard drive-bracket with the screw holes on the NEW hard drive.
  7. Dell Inspiron 13z 5323 Hard Drive Replacement, Replace the Screws: passo 7, imagem 1 %32
    • Replace the screws that secure the hard-drive bracket to the hard drive.
  8. Dell Inspiron 13z 5323 Hard Drive Replacement, Connecting the Hard-Drive Cable: passo 8, imagem 1 %32 Dell Inspiron 13z 5323 Hard Drive Replacement, Connecting the Hard-Drive Cable: passo 8, imagem 2 %32
    • Connect the hard-drive cable connector to the hard-drive assembly.
  9. Dell Inspiron 13z 5323 Hard Drive Replacement, Align the Screw Holes: passo 9, imagem 1 %32
    • Align the screw holes on the hard-drive assembly with the screw holes on the computer base.
  10. Dell Inspiron 13z 5323 Hard Drive Replacement, Replace the Screws: passo 10, imagem 1 %32
    • Replace the screws that secure the hard-drive assembly to the computer base.
Conclusão
Terrence15
Membro desde: 12/18/17
79.121 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.985 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 590
