Ir para o conteúdo principal
Dell Inspiron 1320 Display Assembly Replacement
O que você precisa
  1. Dell Inspiron 1320 Display Assembly Replacement, Disconnecting the Display Cable: passo 1, imagem 1 %32
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer)
    • Disconnect the display cable and the camera cable from their respective system board connectors.
  2. Dell Inspiron 1320 Display Assembly Replacement, Remove the Screws: passo 2, imagem 1 %32
    • Remove the six screws (three on each side) that secure the display assembly to the computer base.
  3. Dell Inspiron 1320 Display Assembly Replacement, Dislodging the Antenna Cables: passo 3, imagem 1 %32
    • Make note of the cable routing and carefully dislodge the Mini-Card antenna cables from the routing guides.
    • Lift the display assembly off the computer.
  4. Dell Inspiron 1320 Display Assembly Replacement, Placing the Display Assembly: passo 5, imagem 1 %32
    • Place the NEW display assembly in position and replace the six screws (three on each side) of the display assembly.
    • Route the Mini-Card antenna cables through the routing guides.
  5. Dell Inspiron 1320 Display Assembly Replacement, Connecting the Display Cable: passo 7, imagem 1 %32
    • Connect the display cable and the camera cable to their respective system board connectors.
Linha de Chegada
Uma outra pessoa concluiu este guia.
Terrence15
Membro desde: 12/18/17
79.091 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.985 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 264
