Ir para o conteúdo principal
Dell Inspiron 1318 Memory Module Replacement
  1. Dell Inspiron 1318 Memory Module Replacement, Popping up the Memory Module: passo 1, imagem 1 %32
    • Follow the procedures in Before You Begin.
    • NOTICE: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on the back of the computer).
    • NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
  2. Dell Inspiron 1318 Memory Module Replacement, Remove the Module: passo 2, imagem 1 %32
    • Remove the module from the connector.
  3. Dell Inspiron 1318 Memory Module Replacement, Align the Notch: passo 3, imagem 1 %32
    • Align the notch in the module edge connector with the tab in the connector slot.
  4. Dell Inspiron 1318 Memory Module Replacement, Sliding the Module: passo 4, imagem 1 %32
    • Slide the module firmly into the slot at a 45-degree angle, and rotate the module down until it clicks into place. If the module does not click into place, remove the module and reinstall it.
    • NOTE: If the memory module is not installed properly, the computer may not boot.
Linha de Chegada
Terrence15
Membro desde: 12/18/17
79.121 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.985 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 75
