Ir para o conteúdo principal
Dell Inspiron 1318 Hard Drive Replacement
O que você precisa
  1. Dell Inspiron 1318 Hard Drive Replacement, Remove the Screws: passo 1, imagem 1 %32
    • CAUTION: Before you begin any of the procedures in this section, follow the safety instructions shipped with your computer. Follow the procedures in Before You Begin.
    • NOTICE: Hard drives are extremely fragile. Exercise care when handling the hard drive.
    • Remove the four M3 x 3-mm screws and slide the hard drive away from the bay.
  2. Dell Inspiron 1318 Hard Drive Replacement, Remove the Screws: passo 2, imagem 1 %32
    • Remove the two screws from either side of the hard drive bracket and pull the hard drive away from the bracket.
  3. Dell Inspiron 1318 Hard Drive Replacement, Placing the Hard Drive: passo 3, imagem 1 %32 Dell Inspiron 1318 Hard Drive Replacement, Placing the Hard Drive: passo 3, imagem 2 %32 Dell Inspiron 1318 Hard Drive Replacement, Placing the Hard Drive: passo 3, imagem 3 %32
    • Place the NEW hard drive in the bracket and replace the two M2 x 3-mm screws on either side.
    • Slide the hard drive into the bay.
  4. Dell Inspiron 1318 Hard Drive Replacement, Replace the Four Screws: passo 5, imagem 1 %32
    • Replace the four M3 x 3-mm screws on the hard drive.
Linha de Chegada
Terrence15
Membro desde: 12/18/17
79.121 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.985 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 572
