Ir para o conteúdo principal
Dell Inspiron 1300 Hard Drive Replacement
O que você precisa
  1. Dell Inspiron 1300 Hard Drive Replacement, Loosen the Captive Screws: passo 1, imagem 1 %32
  2. Dell Inspiron 1300 Hard Drive Replacement, Lifting the Cover: passo 2, imagem 1 %32
    • Lift the cover off the computer and set it aside.
  3. Dell Inspiron 1300 Hard Drive Replacement, Sliding the Hard Drive: passo 3, imagem 1 %32
    • Slide the hard drive carrier away from the screw holes, and then use the tab to lift the hard drive straight up to remove it from the computer.
  4. Dell Inspiron 1300 Hard Drive Replacement, Installing the NEW Hard Drive: passo 4, imagem 1 %32
    • NOTICE: Use firm and even pressure to slide the drive into place. If you use excessive force, you may damage the connector.
    • Seat the NEW hard drive into the bay, and then slide it into the connector by sliding it toward the screw holes until it is fully seated.
  5. Dell Inspiron 1300 Hard Drive Replacement, Replace the Cover: passo 5, imagem 1 %32
    • Replace the cover and tighten the screws.
Conclusão
Terrence15
Membro desde: 12/18/17
79.585 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
43 Membros
Autoria de 1.985 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 28
Ao todo: 1,426
