Introdução
In this guide, we will show you how to remove and replace the Hard Drive.
O que você precisa
Turn the computer over, and loosen the two captive screws in the hard drive cover.
Slide the hard drive carrier away from the screw holes, and then use the tab to lift the hard drive straight up to remove it from the computer.
Seat the NEW hard drive into the bay, and then slide it into the connector by sliding it toward the screw holes until it is fully seated.
