Ir para o conteúdo principal
Dell Inspiron 13-7373 Keyboard Replacement
O que você precisa
  1. Dell Inspiron 13-7373 Keyboard Replacement, Back Cover: passo 1, imagem 1 %32 Dell Inspiron 13-7373 Keyboard Replacement, Back Cover: passo 1, imagem 2 %32 Dell Inspiron 13-7373 Keyboard Replacement, Back Cover: passo 1, imagem 3 %32
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Remove the ten 7.5mm Phillips #00 screws from the bottom of the laptop.
    • Use an opening tool to remove the bottom half of the case from the laptop.
  2. Dell Inspiron 13-7373 Keyboard Replacement, Battery: passo 2, imagem 1 %32
    • Use a Phillips screwdriver to remove the four screws holding the battery in place.
  3. Dell Inspiron 13-7373 Keyboard Replacement: passo 3, imagem 1 %32 Dell Inspiron 13-7373 Keyboard Replacement: passo 3, imagem 2 %32
    • Pull the plastic tab on the battery cable to disconnect the cable from the battery.
  4. Dell Inspiron 13-7373 Keyboard Replacement: passo 4, imagem 1 %32 Dell Inspiron 13-7373 Keyboard Replacement: passo 4, imagem 2 %32
    • Remove the battery from the laptop.
  5. Dell Inspiron 13-7373 Keyboard Replacement, Fan: passo 5, imagem 1 %32
    • Remove the two screws holding the cover for the fan.
  6. Dell Inspiron 13-7373 Keyboard Replacement: passo 6, imagem 1 %32
    • Unplug the connector holding the fan’s wires.
    • Remove the fan from the laptop.
  7. Dell Inspiron 13-7373 Keyboard Replacement, Network Card: passo 7, imagem 1 %32
    • Use the Phillips #00 screwdriver to remove the single screw holding in the network card.
    • Remove the network card from the laptop.
  8. Dell Inspiron 13-7373 Keyboard Replacement, Daughterboard: passo 8, imagem 1 %32
    • Use the Phillips #00 screwdriver to remove the two 1mm screws holding in the daughterboard.
    • Remove the metal piece holding in the daughterboard.
    • Disconnect the two cable connectors from the daughterboard.
    • If the cables are stuck, gently wiggle them until they disconnect.
  9. Dell Inspiron 13-7373 Keyboard Replacement: passo 9, imagem 1 %32
    • Remove the daughterboard.
  10. Dell Inspiron 13-7373 Keyboard Replacement, Motherboard: passo 10, imagem 1 %32
    • Remove the seven 2mm screws securing the motherboard.
  11. Dell Inspiron 13-7373 Keyboard Replacement: passo 11, imagem 1 %32 Dell Inspiron 13-7373 Keyboard Replacement: passo 11, imagem 2 %32 Dell Inspiron 13-7373 Keyboard Replacement: passo 11, imagem 3 %32
    • Release the IO Board Cable.
    • Release the Touchpad cable.
    • Release the keyboard back-light cable.
    • Release the keyboard cable.
    • Release the eDP cable.
    • Release the dc-in cable.
    • Release the cable for the LED charging indicator by gently pulling up on the connector.
  12. Dell Inspiron 13-7373 Keyboard Replacement: passo 12, imagem 1 %32
    • Gently lift up on the motherboard to remove it.
  13. Dell Inspiron 13-7373 Keyboard Replacement, Keyboard: passo 13, imagem 1 %32 Dell Inspiron 13-7373 Keyboard Replacement, Keyboard: passo 13, imagem 2 %32
    • Use the Phillips #00 screwdriver to remove the eight 1mm screws at the back of the keyboard.
    • Remove the 3 screws holding the hinges of the laptop on each side.
  14. Dell Inspiron 13-7373 Keyboard Replacement: passo 14, imagem 1 %32 Dell Inspiron 13-7373 Keyboard Replacement: passo 14, imagem 2 %32
    • Lift up on the hinges that the three screws were removed from.
    • They are difficult to move and may require a tad bit more effort.
  15. Dell Inspiron 13-7373 Keyboard Replacement: passo 15, imagem 1 %32 Dell Inspiron 13-7373 Keyboard Replacement: passo 15, imagem 2 %32
    • Gently remove the keyboard from beneath the hinges that were lifted up.
Conclusão
Equipe
UMass Dartmouth, Team S1-G4, O'Connell Fall 2019 Membro de UMass Dartmouth, Team S1-G4, O'Connell Fall 2019
UMASSD-O'CONNELL-F19S1G4
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 48
Duração total: 1,610
